Midship cleat?
tractoman
Anybody ever add a cleat to the midship area of your boat? I 've been thinking about it because it would be very useful at times when I can't get enough dock to tie up due to other boats sitting there for extended periods loading all there crap.
45Auto
Re: Midship cleat?
Every boat I've ever had has had midship cleats. Just make sure you glass in some kind of backing behind the hull when you put them on.
woosterken
Re: Midship cleat?
mine has them, your right for tight spots or putting spring line on ,if your going to leave it in the slip for a time.
woosterken
haulnazz15
Re: Midship cleat?
Ours has them as well, do as suggested above and use a backing plate. I find the useful for hanging extra fenders as well
jay_merrill
Re: Midship cleat?
I have them "at the thirds." My boat is 18' and has a total of ten cleats - two at the stern, four along the rails, two at the bow (edges because its a truhull) and one located to either side of the bow light.
PGFISHER
Re: Midship cleat?
Go ahead and add extra cleats; you'll be surprised at how many times the existing cleats aren't exactly where you want them.
JoLin
Re: Midship cleat?
I've added cleats, too. There never seem to be enough of them in the right places.
Given the size of your boat (18') and assumed weight of it (2000-2500 lbs?) you don't need to go crazy with backing plates. !/8" stainless or 1/4" aluminum is preferable, but you can get by fine with stainless fender washers (that's FENDER washers. not the standard sized ones),
My .02
Home Cookin'
Re: Midship cleat?
agreed; your mid-ships cleat will not be used for anything taking any stress.
Good for an anchor or sea anchor to trun your boat sideways for fishing. Just be careful.
Brewman61
Ensign
Re: Midship cleat?
Added a pair of retractable mid ship cleats a couple years ago. Was a good move on my part. The Boat has a bow cleat and one stearn cleat at each corner, but nothing else. I use the midship cleats to tie off at my slip.
Found a pair on ebay that matched my existing ones exactly.
scutly
Re: Midship cleat?
my old 23 footer had 9 perfectly placed and my new 29 footer only has 5 and 2 are unreachable from the cockpit. im definitely adding at least 2. right now my bow lines share one cleat mounted in front of my windlass and my stern lines and spring lines share cleats. PITA!
bigbad 4cyl x2
Re: Midship cleat?
; 3 on each side in the bow 1 each side in the back ,and 2 in the stern/transom area
jay_merrill
Re: Midship cleat?
My .02
That's worth more like 2 bucks, not 2 cents.
I buy aluminum flat bar at the big box stores. The 2 inch wide stuff works well - just cut a length of it about equall to the full length of the cleat. Drill holes (a little oversized) at the appropriate places and use for backing.
royal0014
Master Chief Petty Officer
Re: Midship cleat?
Cleats and screwdrivers. What do they have in common??
You can never have too many.........;)
Hawk Eyes
Re: Midship cleat?
My boat had the standard two bow and two stern. I added midship cleats becasue its usless to hang fenders from the bow when that part of the boat will NEVER touch the pier when tied. Now I have a place to hang a fender and protect the foward half of my boat.
