milky discharge on muffs
mygrady
225 94 2stroke.
Should I see milky/water from my prop hub while running with my muffs. I'm guessing that it is a water/oil mix. I just cleaned my carbs and checked the TPS along with adjusting the oil rod due to some binding. I adjusted the oil rod with the carbs fully closed.
Just trying to be safe.
coolbri70
Re: milky discharge on muffs
2 stroke oil from the fuel mix
mygrady
You are saying that it's what I should be seeing along with oil smoke. I realize that this discharge is under water when not on muffs.
Thanks
greg daigle
check the prop seals too see if they leaking and check lowerunit oil if its milky
