Milky gear lube thru coupler
rob 135
Last 2 trips out had gear lube in bilge . First trip of about 15 miles. Checked outdrive and was 5 oz. low . I flushed and filled with new lube. Well this weekend went 25 miles and had same lube in bilge and around coupler after I cleaned it well. Lost 11 oz. lube from out drive. Bilge doesn't really look like it has that much lube in it , but I'm sure most is collected in bellows. Which seal would I be looking at to replace? Outdrive fluid is milky so getting water in . I guess my season may be done sooner than expected. 1985 Scorpion 186 pre Alpha outdrive. 5619758
