Milky lower unit oil 4.3
Stingray1961
Hi just changed my lower unit oil little frosty. Which seal would be letting water in. would it be the one on the shaft of the lower untit. The loiwer unit is only two years old.
Re: Milky lower unit oil 4.3
Ayuh,... It could be Any of them,+ All of 'em are Suspect....
A Pressure,+ Vacuum test will tell you Which 1...
fossill
Did you replace the gaskets on the drain and fill plugs with new ones when you changed the drive oil?
