milky motor oil
cadester
I bought this boat the oil is milky, havent had a chance to change it and see if it happens again but is there a chance its just drawed moisture or the guy didnt change it for a long time??
HT32BSX115
Re: milky motor oil
Howdy. 2 chances. Slim and none.
Slim's on vacation.
Milky oil is usually (not always) but usually a cracked block.
Since you already have the boat, you could change the oil and see what happens.
I think you'll see the "milk" again.
Sorry about that.
Rick
Re: milky motor oil
Slim's on vacation.
Ayuh,... I agree with Rick,...
Although I heard Slim is a Wisconsin school teacher, 'n she's out on strike....
edit;... Mornin' Don,... Where' you come from,..??... :D
cadester
Re: milky motor oil
If i would only looked closer when i was getting ready to buy this boat. I found a crack in the block that goes from the front to the back on the alternator side.
HT32BSX115
Re: milky motor oil
Yeah. they also crack up under the (combined) manifold on the port side just below the head gasket.
I replaced one of those a couple years ago for a friend that didn't fully drain his block. Even in Western Wa, it's cold enough long enough to crack a block.
We used a long block engine from USENGINE in Kent Wa.
We also replaced the manifold.
Good luck...
Rick
