Milky oil from my outdrive
hien331
I have a 1990 Volvo Penta 570a and I believe my outdrive is a 290DB. I know I definately have a water leak. What is the best way to find where the leak is or where can the leak might be? thanks in advance! Also I got the prop cover out but the prop will not come out. I believe it was grease when put back in. What is the best way (tool) to get for that. Thanks again!
captmello
Re: Milky oil from my outdrive
You'll need to pressure test the drive to locate the leak. Not sure on your prop, Is it a Duo-Prop, 290DP?
Don S
First thing to do is disconnect the bellows and see if there is water in it.
captmello
http://www.volvo.com/volvopenta/global/en-gb/marine_leisure_engines/parts_service/publication_search/publication_search.htm
In the link above type 570a in the 'engine type' field and download the owners manual. It may give some insight on your Prop issue. I know there is another member here with the same outdrive and experience with the maintanence of the older Duo Props, Maclin I believe. Perhaps he'll be around with some advise.
Did you check for water in your bellows yet? Thats your first move like Don said.
Good Luck to you.:)
hien331
Good Luck to you.:)
Thank you for your help. I haven't check if theres water in the beloows yet. I will try it this week. Thanks again!
