Milky Oil in 2006 Glastron GX 205 with Volvo Penta 5.0 GL-E
Karri
I'm a newbie to this forum and not a mechanic but was hoping some experts on here might be able to validate our theory and plan with our milky oil issue.
20210619_194616913_iOS.jpg20210619_194629547_iOS.jpg20210619_192513000_iOS.jpg20210619_193050025_iOS.jpg20210619_193027931_iOS.jpgInked20210619_194232964_iOS_LI.jpg
We've owned our boat about six years and at the end of last summer, the boat died on us when towing a skiier. Temp was fine. It would turn over and not start. Tried lots of things and it actually started running again after we started towing it back. In any case, the boat repair shop said fuel pump was bad so replaced and confirmed all good with sea trial. We picked it up and didn't use it again last year. We live in the Seattle area so pretty mild winters and we store it in an insulated basement garage where there is just no way it can freeze in there. Regardless, my husband always runs the pink antifreeze through the motor and fogs the carb before storing it in the garage. He also lowers the motor down to floor level. Yes, not perfect winterization, but we figured even the anti-freeze was probably more than it needed since it was in an insulated garage.
When he pulled it out last month to get ready for the season, he hooked it up to the garden hose and ran the motor about 10 min to make sure it was running fine. He then let it cool and went to change the oil and found it milky. He drained it anyway and added new. Ran again about 10 mins and oil was milky again, like Bailey's irish cream. Yikes!
Our friend knows motors well so they were pretty sure the heads were cracked or the head gasket was bad so they decided to take the motor apart. In hindsight we realize we should have done a compression test and other stuff but too late. So big mistake there but too late now.
Upon first inspection by the two of them, nothing seemed terribly wrong. So we took the boat disassembled to a boat repair shop and they were certain the block was cracked. The thing is, that made NO SENSE to us given how it was stored over the winter. We took it home and people advised us to clean the valley so it is spotless and then re-inspect. We were told almost always the crack will be there. After doing this, there are simply no visible cracks we can see (see photos ).
The next step is we took the parts to a local machine shop and they were super helpful. Immediately they saw that the intake manifold must have been machined by a previous owner because the surface had ridges instead of being smooth. The machine shop guy couldn't believe how poorly it was machined with the grooves. He also showed us where metal was worn away two places (see pictures). He said with the engine pressure, he is quite certain that is the source of water getting in.
As for the heads, we are having them pressure checked by the machine shop and we will know the results Monday.
Given all of this, we are thinking the following:
1. Water is almost certainly coming in from the intake manifold - replace the entire thing (people suggested Edelbrock brand).
2. We see two light brown areas on one corner of the block (see photo) so are wondering if the head gasket might also be leaking some. Would that light brown indicate such? In any case, head gasket will be replaced.
3. If heads are bad, replace, otherwise no action needed
4. Put engine back together and pray the issue is fixed
Oh, and while we are at it, we will replace the exhaust manifolds as we don't think that has ever been done and we've heard freshwater boats should have this done every 10 years.
Question: We are petrified we will put all of the labor into putting the engine back together and still end up with milky oil. Are we missing anything? Any other suggestions? It just seems so unlikely at this point the block is cracked and that repair is so major, costly and lengthy. Are we doing the right thing?
Augoose
The very next thing I would do is pull the exhaust manifolds and risers and inspect them.
Karri
Thanks Augoose. They look fine. We are going to replace them anyway as they are old. Thanks again for your reply.
Lou C
Interesing there looks like there was some pitting on the intake sealing surface that maybe the PO tried to resurface out, but you can only go so far before the intake will no longer match up to the cyl heads due to the geometery of how it fits together. If your heads are good make sure to use a thread chaser on the cyl head bolt holes in the block, so that you get proper torque when re-installing them. If the bolts are not in very good shape I'd replace them too. I don't know if I'd reuse that intake, because intake leaks are common as it is on Vortec engines. I had to resurface mine to get all the old gasket material off but did it by hand with a sanding block (took FOR EVER to get it right) and after that I picked up a couple of spare 4.3 intakes off of ebay. The Vortec ones for the V8 are easy to find. You can go to the Edlebrock but keep in mind it is aluminum which introduces the possiblity of leaks due to dissimilar metals. I think the stock cast iron intake is probably best. Keep in mind also that the Vortec intake torque specs are much lower than the pre-vortec was, this is a frequently made mistake. Pre-vortec was like 30-35 ft lbs, the Vortecs are much less, like 10-12 but you have to check to make sure.
PS
you might want to alter your winterizing procedures, running AF through, if you did not drain the block first or remove the thermostat, is not doing anything because:
with an engine idling on the water hose on a cool day, the stat will NOT open enough to let the raw water exit the engine. The stat on these functions as a gate valve to keep the engine temp around the temp of the stat rating (160). So running the AF through like that, you get exhaust manifolds full of AF, but the engine could still have raw water in it. And crack if you had a power outage, or unforseen colder than normal weather like Tx had this year. Best practice is to drain manually, poke drain holes, to make sure no rust flakes are clogging and then back fill with AF to reduce corrosion. I've done it that way close to 20 years and never had a problem down to zero degrees, and even in salt water my intake block or heads never rusted through.
the machine marks are common on even new intakes. the as-cast surface needs to be machined prior to the intake being used.
that intake is made for Volvo by Buddy Barr castings (same company that does Edelbrock castings.
the corrosion where the bronze and aluminum are can be bead-blasted and filled with a good metal filled epoxy such as devcon
how does the exhaust manifolds look?
cptbill
I'm with Scott, the the biggest issue I've had with mine is exhaust manifolds and risers, and now I do not run the factory gaskets between the riser and manifold I use a fiber one and that seems to work a lot better for me
Lou C
When I converted my old OMC one piece exhaust to the newer 2 piece later OMC/Volvo style I used Barr marine aftermarket exhaust and their gaskets with Permatex Aviation sealer. Worked great, did this 4 years ago and no leaks. 100% salt water.
Karri
PS
Karri
I'm sorry to be so delayed but we've been trying to figure out what to do. We ended up taking the boat to a different repair shop to get a second opinion. They actually think the intake manifold is ok and not the culprit. Exhaust manifolds look good too and the heads were pressure tested fine. After further study by several at the shop, our current theory is that the water came in when the boat died under power when towing a skier and the first shop we took it to didn't check the oil! That would be almost negligence but it is the only thing that makes sense. We have this theory because there is a water mark inside the cylinders as though water was left sitting for awhile (e.g. during the winter) and some minor rust in the manifolds but only on the horizontal surface, meaning nothing on the risers, leading us to believe it didn't leak in continuously. If this is the case, the good news is no need to replace the block but the bad news is we made terrible mistakes because we could have drained oil a few times and the problem would be fixed vs the thousands we will now be putting into it for reassembly. We feel a bit like idiots but we learned our lesson to go slow, do research and find a reputable shop. Thank you so much for your reply. Oh, and yes we agree that a new winterization procedure is needed and will be done this fall. Fingers crossed all is good when it is reassembled. Thanks again
Karri
I just posted a longer reply. They look good for the most part. Some small rust on the horizontal surface but the new repair shop feels they are fine and to not bother spend $ to replace
