Corvettedude2
Thread starter- Joined
- Jul 4, 2022
- 9
Hey everyone about 4 years ago I posted here about milky oil in my 2007 stingray with a volvo penta 3.0. It was under a different account I was unable to access. Yall were very helpful back then and helped me trouble shoot with pressure testing the cooling system and compression test. I pressured tested the block and it held 20 psi for like 8 days so yall determined I should change the oil and try it again and it never had a milky oil problem again i posted all about that outcome years ago. Fast forward 4 years to now and the boat has been fine this whole time and been out 3 times this year and been fine until today. Took it out for the fireworks and I always check the oil when I get home and put it in the garage and there it is again milky oil. What could cause this intermittent milky oil problem? It used to "diesel" bad when I shut it off and I remember someone here said that could cause it but yall said to allow it to idle for a minute before shutting it off and I've never had a diesel or run issue since I started doing that
