Re: milky oil
Water is in your oil -- you likely have a bad seal in your gearcase somewhere. <br /><br />The easiest way to find out for sure is to attach a hose (airtight) to the drain port, sink the gearcase underwater, and watch for bubbles as you pump air into the tube. (Don't exceed 5-10 psi)<br /><br />Wherever the bubbles come out is where you need a new seal.
