- Joined
- Apr 17, 2002
- 71,520
Hey Guys,......<br />I'm trying to repair a borrowed welder,+ I'm running Blind.... No real experience with Onans,+ No Book........<br /><br />Welder; Miller Bobcat, 225G, powered by an Onan, P216G-I....<br /><br />History; OLD,... Welded a bead long enough to go around the World, at least once....<br /><br />They had an issue with it lately(wouldn't run),+ the mechanic replaced the Coil.......It Ran Fine....<br /><br />Then,... I went + borrowed it..... Ran it Maybe 8hrs.... It had fallen back to the low idle speed after the little lady had finished the bead she was doing.... As we spoke about the next series of welds she was going to lay-down,........ The Welder Just Shut Off.........<br /><br />I figured it was over due for Gas, so I filled it up..... Didn't take enough though....<br />Wouldn't Start........<br />Pull a plug,+ do the ground it,+ Watch for spark test... Nothing....<br />Testlight says it's got power to the (+) side of the coil,with the switch On,+ Blinking power on the (-) side of the coil, while Cranking........<br /><br />My Conclusion,..... Bad Coil..... <br /><br />Wrong.....<br /><br />I found another New coil($56.) yesterday,+ installed it today....<br />Still No Start..???.... No Spark at the plugs...<br /><br />Just went out,+ checked somemore... Now have power at the (+)side of the coil, with the switch On... Now Do NOT have blinking power at the (-) side of the coil, while Cranking..????<br /><br />There's a Capacitor with it's wire to the (+) side of the coil, It appears to be Original(looks like the condensers I used to replace with the points, Years Ago).....<br /><br />Question; What's it's Purpose ?? How do I Test it ?? Will it run Without it ??<br /><br />Next Question; Which Way do I turn the Muffler-Bearing to get this Dog Ganm thing to Run..?????<br />Any Ideas.... Hints..... <br />I'm Not Quite ready to Check the Gastank with a Match,................ Yet..................
