Mini Fuel Filter and 90HP TLR
RobG
When replacing the Yamaha mini screw on fuel filter, should you purge any air that is between the primer bulb and filter. I've changed my filter and noticed that now the primer bulb doesn't get firm when pumping fuel into the motor. I can hear it trying to pull the fuel from the tank and it must be because the motor starts. I haven't found any leaks either.
Thanks for the help!
Rob
hribarj
Re: Mini Fuel Filter and 90HP TLR
Sorry to interfere but I'm new and I can't figure out how to start a new thread. Can you help?
THANKS
RobG
I realized what I had to do. Disconnect the primer bulb from the motor and depress the connector while holding the primer bulb straight up and down. give it a few good pumps and the air will bleed right out. Just have a few rags available so that you don't make a mess. Gas is expensive!
Rob
