Minn Kota 50 lbs thrust , Ok as a kicker??????
wa3ipb
Hello, Would a 50lb thrust Minni-Kota be useful as a kicker for a 17Ft. Tri-hull? We have an opportunity to get this.Thanks all!
12Footer
Re: Minn Kota 50 lbs thrust , Ok as a kicker??????
It should do great as a kicker on that hull. I have a 30lb thrust on my bayliner same size(emergency kicker). The one and only time I used it, I was 5 miles from the ramp. It got us back in 2 hours.<br />So with 50lbs, you should be fine.
wa3ipb
Hi 12Footer
Well I just bought it. Would you "e" us please at "Deleted". I have a few more questions about this. Thank You!
12Footer
Ok, I sent you a msg, but I may not get a reply, if i don't recognise the sender (been getting hacked lately)..So put "iboats" in the subject line,and I'll know it's safe,and it's you.
aban_esox
Where do you want to get kicked to!!!<br />If this emergency backup, I would really reconsider. How fast does the weather change where you boat. Here on Lake MI it can change in a matter of minutes.
12Footer
We have some quick change weather here too, Essex. But a good TM and a hot deep cycle beat a set of oars any day.<br />I would rather have a pair of counter-rotating outboards tho.
