Minn Kota 55LB probelm please help
sadetre
I Was Thrown Into The Docks By The Wake Of A Big Boat
My Trolling Motor Took The Brunt Of The Impact.immediately After Wards It Would Run But It Was Slipping ,
I Tried Taking The Prop Off But The Nut Just Spins,can Anyone Suggest A Way To Take It Off.
Thank You In Advance For Your Help
Fish Fishman
Barnacle_Bill
Re: Minn Kota 55LB probelm please help
If holding the prop does work then the shear pin is shot. There should be a slot in the end of the prop shaft for a screw drive. You can use this to keep it from spinning while you take the nut off with a wrench.
david_r
Fish Fishman
what ever happened to the no wake zones?
i would have been a little aggravated and would probably have voiced my opinions to the owner of the other boat........here you are responsible for the damage your wake causes and trollers arent cheap.
sadetre
Bhile I Tried Looking For A Manual No Luck
I Also Tried Putting A Screwdriver In The Groove And Using A Wrench To Hold It No Luck
The Groove For The Screwdriver Is Very Thin And Narrow I Need A Plan C A And B Doesn't Work
Please Any Other Ideas Thanks
U R Right David But I So Worried About Sinking Thats Why I Didn't I Didn't Have Time To Get His Id # I Was Taking On Water.
Silvertip
There isn't another plan (except for cutting the prop off) and that's why the slot was put in the shaft. Buy a screwdriver that fits the slot or grind one you have so it does fit.
