StuBone278
Thread starter- Joined
- Jan 21, 2008
- 33
I've had this Endura 36 for about 4 years now and it never gave me any problems, until about two months ago it started making a nasty grinding sound when it was running, but then when you put the speed to 5 it would sometimes go back to sounding just the same. I figured it could have fishing string in the prop so took the prop off and there was a little nest that I cleared with no problem, but it still was making a grinding noise, and then just couldn't turn the motor (but you could hear it trying to crank over). I went back and took the actual motor out, and it was completely filthy, with corrosion and oxidation on the copper EVERYWHERE. I washed what I could, put it back together, and it still just couldn't turn over, even with a fully charged battery. Any help would be greaty appreciated. I really don't want to have to buy a new motor, much less send it to a repair shop (might as well get a new Motorguide 30 for $100)
Thanks, Stu
Thanks, Stu
