Dodger1234
Thread starter- Joined
- Oct 5, 2008
- 89
After doing a search on this site it seems the recommendation is fuses, fuses, and more fuses. I purchased a new boat 2 years ago and today I checked my wiring to see if they had installed fuses. The motor and fish finder are fused in but the bow mount Minn Kota goes directly into the deep cycle battery ( factory wires ) and the positive on the battery goes back to the 1,2, both, off switch then is hooked up to the positive on the cranking battery. The negative goes straight to the neg post on the cranking battery. SO, if a fuse is needed for the bow motor why is there nothing on the positive line to the battery from the factory? Is there possibly an internal fuse? I have the V2 Powerdrive 55 LB. If I need to cut the positive line and install a fuse how big of a set up do i need?
Thanks for any advice Dodger 1234.
