minn kota issue
laopi313
Hi, I had a 45lbs Minn Kota motor with Power Drive foot pedal, the propeller did spin, left and right turn working.
I disassembled the motor, and measure the voltage between the brushes, it shows about 12.5v, so I assume the food pedal working, and I measured the resistance between two coppers, the value is the same, the springs look fine, so I assume the armature is working.
I heard most of issue will come from the brushes, but I only find the brush become a little bit curve instead of flat, is it the issue? any thought?
peter
