Ifish . . .
And by the way, the question you asked about the mounting position of a bow mount was a good one because I've always used a transom unit and I always wondered if I went up to a bow mount unit with my other boat how would it be mounted. I never wanted to give up the front deck space.
The boats I've used which had the foot controlled bow mount were not mine, so I never really concentrated on how they were mounted exactly.
But after I use the one below on my daughter's rig, I'll probably be hooked.
Below I posted the mounting pics you asked for. I'm glad I took them because I think I was steered into ordering the wrong bracket for my situation. No ones fault. But I need to use it with a trailerable cover that came with the boat but the previous owner never used it because it didn't fit over the bow mounted troller so he kept it garaged (even better
It looks to Me that overhang is going to force me to bring the cover to my canvas guy and he will have to alter it to fit over the overhang of the bottom part of the bracket I just ordered that is left on the boat after I remove the motor.
I will have to weigh out how much he will charge to alter the cover to fit against getting the other Minn Kota bracket that just leaves a puck on the deck. See picture. See how only the small square composite puck is left on the deck:
Others have said the bracket I ordered is better because it's all aluminum but I'm not worried about a thief stealing the puck when the motors not on the boat. I'm sure for $70 plus the other bracket is strong too.
http://www.minnkotamotors.com/products/accessories/quick_release_bracket/aluminum.aspx
