littlebookworm
- Joined
- Nov 30, 2007
- 574
I'm almost finished refurbishing my 1986 Sunrunner, Mercruiser 5.0, Alpha I drive. I had a slight leak at the power steering hydraulic actuator fitting, so I removed the actuator to tighten the fitting. When reinstalling the actuator, I misaligned the upper bolt and "missed" getting the pin end into the receptacle hole on the actuator. As I tightened the bolt down, the mounting boss broke off the inner transom cover. A local welder said there's nothing he can do. Questions: Has this happened to anyone out there? Where you able to have it repaired, or did you have to pull everything apart and replace the inner transom cover? If replacement was the only option, could you run through the sequence. I have the factory manuals and it seems straight forward, though a real PITA. Is there anything to watch out for? Any tricks in re-assembly? Thanks for any help. Hy
