I have a 50 horse Johnson 1988, all rebuilt, removed the vro, put in a regulare pump. it fires up , timing ok on idle, but misfires out the exhaust with a puff of smoke and intermittently sprays gas out the idle jet. I changed carbs with a similare type but with idle adjust screws.. runs better but still misfires out the exhaust and some gas is seen in the carbs and silencer box. I double checked the timing, opened up the engine again to see if anything is cracked.. but all is ok.. only thing left are the reed valves.. but before I spend the coin, I wanted to get some other thoughts..<br />this is a two cyl. 2 stroke, twin carbs.. the replacement carbs are from a mid 70s engine 55 horse but the choke is different.. oh well, I can work around that.. I just would like to here this purrrr not sputt, cough and choke..<br />thoughts welcomed...
