DunbarLtd
Thread starter- Joined
- Nov 8, 2016
- 357
88 Force 85hp.
During an outing yesterday I noticed a few things regarding misfiring and wasnt sure what to make of it.
Apparently these engines dont like idling for too long because they will carbon up the spark plugs and cause running issues.
With mine, it will sputter and miss like crazy until I get up to speed and it eventually "clears out". After that, at speed, it will run fine with no miss.
So I got curious and when it started missing again after idling around for a bit i hooked up a timing light.
First of all , I marked each TDC cylinder on the top of the flywheel with white paint so i could easily see when the cylinder was firing. Interestingly, on the flywheel there are notches that coincide with the three marks. I numbered them 1,2,and 3.
When hooking up the light as its missing I noticed with the lead clipped to #1 plug wire.... #2 and #3 would light up intermittently. As I hooked the lead to #2 and #3 coil wires the same thing would happen.
Very similar to what you see in this video here: https://www.youtube.com/watch?v=D-hBeGdE6oE
I am not sure what is going on. If a spark plug were to get carboned up and misfire, when I hook up a timing light; wouldnt I just see the #1 mark show up on the flywheel intermittently?? Why would a fouled plug cause #2 and #3 to spark at those times like in the video? In the video that are saying its an indication of a faulty trigger.
To further my test I again hooked up the light after i made a run making sure the engine had cleared and wasnt missing. Shifted into neutral and kept it running.
Every single cylinder was firing exactly as it should without any misfiring according to the numbers on the flywheel showing up.
Why would #2 and #3 be firing when I have the lead hooked up to the #1 wire during a misfiring episode if its clear that the trigger or stator is not bad?? If they were it would misfire all of the time wouldnt it???
Anyone have any explanation to whats going on?
