The Ole Blue
Thread starter- Joined
- Aug 9, 2021
- 11
Hi everyone,
I’m kind of at a loss with this one. I’m running a 2006 9.8 Tohatsu 4 stroke. It’s on the back of my 1986 Meyers Vhull. It’s been moded into a mini bass boat. Cedar frame, 1/2” ply decking, carpet, batteries, ect adds around 200 pounds to the boat so its heavy and I don’t expect it to be fast.
here’s the problem I’m facing. At WOT I am achieving 4900 to 5000 rpm at around 14-15 mph with just myself in the boat. My best day was 5250 at 16.6 mph but this was a rare occurrence. It takes a little time but it does plane up and run pretty well at this speed.
I decided I should probably raise the RPMs a bit to be running optimal range of 5200 to 6000. I looked for a lower pitch prop and did not have many options available. I ended up buying a 8.9x7 pitch to replace the 8.9x8.5 that was on it. I installed the new prop and went for a test run. I stuggled to get on plane and managed 11.5 mph at 4400-4500 rpms max. Went back to the launch and swapped back to the OEM and went back up to 4800 range. I expected the prop change to raise RPM at WOT not lower them.
my question is do you think it’s possible that this prop is just not what it says it is or is it possible I have a different underlying issue with the OB that could be causing this?
it did come from Amazon and was direct shipped from China but it is also marked on the box and prop itself to be a 7P.
I made an adjustment to the mounting height yesterday and bought a couple spark plugs thinking maybe the plugs are foiled (they did look a little black on the threads). I will try to get back out today or tomorrow and go for a run then swap in the new plugs to see if it makes much of a difference. Just wanted to see if anyone had any input in the prop itself.
Thanks
Thanks
