Lakeshadow
- Joined
- May 29, 2012
- 205
Re: Miss Peachtree
I take the little plate off the side then put the muffs on. I have to turn the hose on low because any more and coolant water would be spraying all over the place. Muffs are convenient and the way to go, I've used that thing time and time again and it works perfect. What does water weigh? eight pounds or so a gallon? I used a can once and couldn't get my boat away or get the outboard out from the can, it was a real pain in the keester!
I don't quite understand this post? If the muffs were a bad idea I would have a broken Fastwin by now. And everyone I talked to would of told me not to use the thing.
This is kind of like me telling someone it's a bad idea to beach your boat...
not a good idea to run the motor on muffs :/ it needs to be in a test tank with water filled up to about and inch or two below the main exhaust port.
