Missing at idle
Wonbigfish
I have a 1997 90 hp Force. It has been a great running out board. The last time out I noticed it was missing @ idle and lower RPMs. It seems to clean up when I get boat on plane. This sympton just started last trip out. Can someone point me in a direction for diagnosis. I guess every repair has a starting point.
Thanks ahead of time
Wonbigfish
Jiggz
Re: Missing at idle
I'll start with compression test and visual inspection of the spark plugs. Sometimes when an engine is only missing on one cylinder people tend to think the misfiring goes away at high RPM when in reality it is only masked by the louder noise generated.
Wonbigfish
Re: Missing at idle
Compression test has 150 on all three cylinders. Replaced plugs & water separator filter. It ran great when I started it then after it warmed up it went into a rough idle or missing mode but never died. Any ideals what to look at next. It sure seems like it's something simple but I have had simple things erupt into bigger problems.
Thanks in Advance
Wonbigfish
Jiggz
Re: Missing at idle
Do the following troubleshooting:
As soon as the misfiring or rough idling starts, try squeezing the fuel bulb and see if it gets better. If it does it is fuel related. If not continue on next step.
Using a timing light, watch the constancy of the firing (strobe from the timing light) from each wire plug to see if misfiring is caused electrically. If it is you will need to visually check on the trigger and the stator by removing the flywheel and do resistance checks as well. Also check all wiring make sure none has cracked insulation.
Wonbigfish
Re: Missing at idle
Due to recent algea bloom & truck repairs I am just getting back around to my boat. I changed plugs & thought that was it. NOT. Took it out & it was the same. I ran it at home & put my timing light on all 3 cylinder wires. They all seem to fire consistantly. I then noticed the water from pisser seem to spit or sputter with a little air in it. I then did another compression check. 140 120 140. Is it possible to have a had gasket starting to go. I couldn't help but notice #2 plug looked gray as if water was getting to it. When I get into upper RPMs it runs strong without miss. How can I diagnoise a head gasket. Is there something else to check?
Wonbigfish
jerryjerry05
Re: Missing at idle
Pics of the plugs?
20# doesn't seem like a lot but it is.
Look for water.
Spray some oil in and do another test.If there is water in there it will turn it milky/gray etc.
I had a head gasket go bad. The comp was 145# all three.But the middle hole the gasket was leaking water.
Maybe pull the head?
Be real careful when removing.Tey were only put on with 20# of tourqe.So if they don't go easy, you can break them off.
Wonbigfish
Re: Missing at idle
Thanks JJ
I think I will tear down head. Gaskets are fairly easy to do but, just as easy to screw up. This motor has had little salt time. 2 gaskets can't be that asking to much for a hunch?
Jiggz
Re: Missing at idle
Or you might want to re-verify all head bolts for torques and then try again. If it doesn't improve, then it is time to open and inspect the gasket.
Wonbigfish
Re: Missing at idle
Thanks Jiggz
I will check torques first.
jerryjerry05
Re: Missing at idle
Your not too far away.If you can't finger it out bring it on down?
Wonbigfish
Re: Missing at idle
Tore into it today Head gasket is the problem. What is the torque spec for head bolts on 1997 90hp force?
jerryjerry05
Re: Missing at idle
I think 20# is the tourqe.
Some say to re-tourqe after a short time,some don't.
I've never found it necessary.
Wonbigfish
Re: Missing at idle
120 inch #s plus 1/4 turn as works out. Repair is complete & ready for Mosquito Lagoon
Thanks for all the help
