- Joined
- Oct 25, 2011
- 25,334
No, IMO either epoxy or Poly resin is more expensive and harder to work w. Epoxy takes a while to cure, polyester is a hazmat. TB3 is water cleanup until it cures and water/boil proof when it does, and cures fairly quick. Polyurethane glue is abut midway between easy/forgiving and being more difficult to use.
My last 2 ply transom glue ups were done w polyurethane (gorilla both times) but thats because I wanted to use it the 1st time and had it left over for the 2nd.
TB3 is about $30/gal here, and will probably do a whole 18ft boat's wood gluing needs, maybe a 21ftr..... Easy to use, relatively cheap (definitely inexpensive) water cleanup before cure, water/boil proof when cured and it cures fairly quick. Whats not to like?
Several have used epoxy to laminate the transom ply. A few even used glass in between the ply sheets. As far as I know, none have come back to complain that they used it w or w out glass.
IMO, no upside to using polyester and glass, and I wouldnt recommend it anywhere else on a build, so why bother?
At least I'd recommend using epoxy elsewhere on a build, so if you have it on hand, you could use it.
But it takes quite a bit, you'll need to mix more then you need, you dont want to leave epoxy voids or run out w out coating the entire surface. That epoxy could have been used elsewhere, and there are other good choices, so why use the epoxy?
As long as you meant epoxy and glass, go ahead and use that if you want to, are comfortable w its use and the slower cure. No problems will occur if its done well....
