Mixing oil with additves?
Todd Humphreys
After reading many discussions on type of oil and additives from this forum, I was wondering if it would be alright to mix your boat oil with a additive and leave it mixed together (i.e. 1 gal. Supertech oil and 16oz seafoam). There is enough room in the 1 gallon supertech jug to hold an additioal 16oz of seafoam. This is the first time to try this, also this recipe is a third of the dose that seafoam recommends. I also know that this slightly dilutes the 50:1 mix when measured out. After half a dozen trips, no problems, so far. Your thoughts :cool:
rickdb1boat
Re: Mixing oil with additves?
You may want to read this:<br /><br /> web page <br /><br />I prefer to shoot the Deep Creep straight into the carbs method every 6 months or so, but I think the above is more of what you are after. No need to do it all the time...
quantumleap
Master Chief Petty Officer
I think you would be better off to mix the seafoam with the gas than with the oil. It seems to disperse better in gasoline.
