Re: mixture force 125 89.
Frank and Chris, you're both obviously the expert on this one. However, I based my post on p.133 of Clymer's 4th edition which discusses spark plug analysis. I've personally done the same and followed the manual to the letter. Yes, too lean can cause major problem. And with too rich of a mixture it could keep fouling your plugs. And its also accurate that the idle mixture only affects lubrication when idling. When the engine revs up and start taking on fuel/oil mixture from the main jets, proper lubrication is basically automatic since there is no adjustment for the main jets. So even if the idle mixture is set at the lower end of the fuel/oil mixture, it'll take a long time before catastrophic damages can occur. And only if the setting is too lean. However, if there is any sign of wetting even at the slightest on the plugs after a long idling, it sure guarantees that there is proper lubrication at idling. As mentioned, there should be a little wetting on the plugs.
Oh another thing, why they keep calling the idle mixture screw an "air screw" is beyond me. The only thing that adjust air is the "butterfly" or throttle valve which is located at the throat of the carb. The idle mixture screw adjusts the fuel going to the idle jets, not air.
