mixture setting for 2000 90HP 60 degree
twowee1s
What is the carburetor mixture setting for a 2000, 90HP, 60 degree Johnson?
tashasdaddy
Re: mixture setting for 2000 90HP 60 degree
go to top secret top of forum adjusting carbs, single needle.
twowee1s
Ok, maybe I should rephrase that. Does anyone know what the factory or service manual settings are for the idle mixture on a 2000 90HP 60 degree?
tashasdaddy
that is exactly why the motor has an adjustable mixture screw so you can set it to run the best for your area, elevation.
twowee1s
The initial setting on a loop V 60 degree model is totally different than any inline with single adjustable mixture needles.
