hipster dufus
Thread starter- Joined
- Jan 1, 2009
- 169
i already did the search for this issue, so here goes. mk legend at 565 46# foot controlled. i also have a transom mount on this boat. the mk does not pull the boat that well unless it is in 5th speed. i use to run on 3rd speed all the time now i have to use 5th to pull the boat the rear tm does not have this problem. the batteries and connectors all look good. there is no line on the prop or any signs of corrosion any where. do the motors just go bad slowly? any other ideas on what to check?. i am not losing voltage along the line from the batt to the plug. thanks
