Mobile1 and Mobile1 high milage formula.
JC1933
Good morning.
Both of my vehicles have milage in the 40.000 mile range my car has 38.000 and my motor home has 41000. I bought some oil on sale and I maid a mistake and got high millage oil instead of the regular Mobile 1.Can this be used even if my engines are low millage?or do I exchange it for regular Mobile 1?
Regards J.C.
JB
Re: Mobile1 and Mobile1 high milage formula.
You can use it or you can ask the vendor to exchange it. It will do no harm either way.
BTW, I well remember the day when 40,000 was considered high mileage.
It is Mobil 1, not Mobile 1
JC1933
Thanks J B for the reply and my spelling error of Mobil 1.
Regards J C.
rbh
We have gone from 10w-30 to 15w-40 on any gas pot vehicle thats high milage and used during the spring and summer, its a little thicker and keeps some of the noises down:)
j_martin
The high mileage formula just has a little solvent in it to soften up the oil seals. Other than that, it's the same stuff.
Speaking of high mileage, I remember when getting to 100,000 was a milestone worth celebrating.
This week I bought a 93 Honda Accord with 218,000 miles on it, caught up on 800 bucks worth of periodic maintenance, and fully expect to drive it 50 to 100 thousand more without major trouble.
I also have a Chev 4.3 V6 engine with 328,000 on it. It needs gaskets and seals, a valve grind, and maybe rings. No crank bearings will be replaced. It will go into a conversion van and be expected to run another 100,000 or so.
The secret is good oil, (I use Tech full synthetic) keeping the fluids up, (they all leak eventually, no harm done as long as you keep it topped off), and religious filter maintenance.
Notice I didn't say frequent oil changes. It's not necessary with synthetic if you keep the filters from bypassing (3000 miles or so) and you're not in extreme conditions, like not warming up the engine in winter, or extreme dust.
With dino oil, frequent oil changes are required because of the chemistry of the oil.
my 02
John
JC1933
Hi Guys
What is your feeling between regular oil filters and synthetic oil filters? hear the regular is under $5.00 and the other for synthetic sells for $14.00 is this high price filter needed
Thanks guys. J C .
j_martin
Hi Guys
Thanks guys. J C .
No.
jay_merrill
My 4.3L V6 is still going strong at 178,000!
