model/serial on 87 Black Max XR-2 location?
CWKboat
Hello,
Just bought this engine and need to know where to look for the serial #?
Transom clamp, or other? Thanks for the help!
Barnacle_Bill
Re: model/serial on 87 Black Max XR-2 location?
There should be a plate attached to the transom mount.
CWKboat
bhile,
Thanks, Ill check it out tomorrow. Just bought the engine.
CWKboat
Re: model/serial on 87 Black Max XR-2 location? (update)
Wow, I found it on the starboard side of the transom bracket. It's actually a sticker and was peeled amost all the way off and barely legible. I should have an interesting time getting it registered with the tax collectors. I peeled the rest of it off and I guess will have to reapply with some adhesive and hope I can get it titled.
Best I could tell it's "0B169260" which I hope is a 1987.
Laddies
Banned
The serial number should be stamped into this soft plug
CWKboat
Laddies,
Thanks! Will try to get a pencil tracing tomorrow. Thanks for being a huge help!
Fun Times
Best I could tell it's "0B169260" which I hope is a 1987.[/QUOTE]
Hello there, Thought I would let you know that your engine serial number "0B169260" would actually be considered an 1986 MERCURY 2.0L 150 XR2 ELPTO from mercury marine.
Engine Model No: 1150766.
CWKboat
Engine Model No: 1150766.[/QUOTE]
Thanks so much for the clarification on that. That helps!
To update the thread, I couldn't find a stamped serial number in the plug on the engine block. Maybe the powerhead was replaced at some point who knows. Hopefullly the titling folks will work with me although the sticker is legible only in the right light.
