model year again, johnson 150
jonesg
I just picked up a johnson 150, its a counter rotating prop, I've looked at the references online but can't figure out the yr.
Inside the cowl the ignition cover states Optical Ignition 2000.
But I don't think its a 2000.
Model number is M J150 w C L R S
according to the codes that makes it a 1940 !
they were way ahead of their time.?
I also can't find reference for the M in the model number,
there is no M in the charts.
Can anyone figure it out? my brain hurts.
Basher
Re: model year again, johnson 150
jonesg,
check your model number again there should be another letter between the L and the R. 5 gets you ten that it is an E and that would make it a 1994
Basher
Dhadley
That's a 1994 150 commercial motor. Commercial motors didn't really go by model years but that's why the E was left out.
jonesg
Is the concensus good on these types?
Its loop chraged...
just trying to learn what I can about it.
What makes it "commercial" ?
I've tried looking up the OEM manual here on Iboats but came up blank, would another similar J150 be the same manual ?
Dhadley
Good motor, probably one of, if not the best design OMC had. The commercial version is very similar to a recreational motor. The heads may have slightly more cc's, the rev limiter may be lower but the powerhead (block, crank, rods & pistons) are the same as the recreational motor. It may have a slightly different gear ratio, you'd have to check. Obviously some styling differences.
