San_Diego_SeaRay
Thread starter- Joined
- Nov 9, 2014
- 346
Engine: 1981 Mercruiser MCM 260
Ignition: Originally a Mallory "points" type ignition but modified to an electronic distributor using a Pertronix Ignitor 2 (PNX ML-181) kit as well as a 3 ohm Flamethrower coil
So today was supposed to be the big day after months of toiling on rebuilding this engine from a heap of rust into a useable engine. When I spoke to the previous owner last November, he told me that he was in the process of rebuilding the boat himself when he gave up. One thing he said he did do was upgrade the ignition to "points" type ignition to electronic ignition. I had to do some detective work, but I've pretty much been able to determine what he did, which I described above.
So today I finally install all the spark plugs and wires. It's a 12V coil, so I skip the resistance wire and just clip a 18 gauge alligator clips to the "+" side of the coil and to the "- "side of the coil, with each going directly to the BAT and GROUND, respectively. I turn over the engine a bunch of times. Nothing. Then I put an inline ignition spark checker between the coil output wire and ground. There's a spark when I start turning over the engine, then a spark when I stop turning over the engine, but nothing in between. After about a minute of turning the engine over, I notice the alligator clip wires are warm. Then I touch the coil. Hot. I'd say about 140 degrees. You couldn't put your hand around it for more than 15 seconds.
So I've got a hot coil and an intermittent spark. What do you guys think?
