I have a 1989 Force 85 HP (on a Capri 1700) with the non through hub exhaust.<br />I picked up a 13.5" x 15p through hub exhaust prop for a song. It is either a Merc or Yamaha prop so the spline shaft fits but the reduced diameter rear collar on the prop is too big to fit my lower unit.<br /><br />I am considering cutting the collar off the prop using a lathe. Is the collar more for weed/silt protection or exhaust flow retention? Since all the exhaust on my outboard comes out the tab on the cavitation plate would removing the collar on this prop hurt anything?<br /><br />I have a Force 13.5" x 17p through hub prop that works good on it now up to 35 mph @ 5000 rpm. I want to try the 15p to get a little more pull and rpm's for tubing and skiing.<br /><br />Thanks
