Moisture in gauges
jukes23
I have 3 gauges (just installed that have condensation building up on them. Is this caused by them being screwed down to tight or too loose?
Thanks,
Joe
a70eliminator
Re: Moisture in gauges
Gauges ususally attach from behind with 2 L brackets nutted to posts on the back of the gauge. I don't see how overtightening could cause that, the brackets usually just bend. Are the gauges cheapies like you get at walmart for a car? If the gauges aren't marine quality that could be a problem i don't know for sure.
Chris1956
Honorary Supreme Mariner
Even good marine gauges can get condendsation in them. A cure is to place an incandesent light bulb near them and the heat will dry them out.
a70eliminator
Hmmm, never ever have had any condensation not even on my 68 MFG gauges, just lucky I guess.
jukes23
No, they are teleflex marine gauges. I didnt wrench them super tight, so its a little confusing. I could see the water pressure gauge possibly getting condensation on it, but voltmeter and gas gauge?
woody66912
some times it's just the nature of the boat.you can wire your gauge lites to your ignition so at least when your using the boat the heat from bulbs will keep the moisture out.
Gary H NC
Thats what i did.Wired them to the switch so the bulbs light up when the key is on.I have one gauge that gets moisture in it and the bulb being on does help it dry out.
