moisture on one carb NEED HELP Yam 150 Pro V 91 Champion 176 s/c
jhosea1979
I have a 91 yamma pro v 150, have been trying to work out a lost rpm's on the motor 800 r so. i was out testing yesterday and i notice a good amount of moisture on the outside of one of the carbs but not to the other two???:confused:
:facepalm:i have spent a lot of time and money trying to get the lost rpm issue fixed. "Part Changing"
What started the whole problem was when i changed the water/fuel separator---then--10-12 mph slower:eek:
Since then i have put new fuel pumps, rebuilt the carbs, new fuel lines from top to bottom no help..............
I had also found a loose wire on my rectifier/Regulator And was noticing voltage spike, So replaced the rectifier Not knowing what else the voltage spikes would have hurt so i went in to part change era--- new cdi, new pulser coil, new stator, new coils :facepalm: Still No help.....
The compressor on the motor is 101-106 SEE Photo's
Any help with this problem would be great, like i said i dont understand why the moisture was built up on the outside of the carb and not the other two is the one working correctly, and the other two not, or visi,versa:confused: this boat and motor use to run around 58-60 grand at around 60-62 "GPS" mph Turning a 13-3/4"x 25" laser II prop....
Now i am only getting About 49-51 @ 50-53 "GPS" MPH
Any information or idea's are appreciated very much i have no clue which way to go now
jhosea1979
Re: moisture on one carb NEED HELP Yam 150 Pro V 91 Champion 176 s/c
jhosea1979
