monkey wards yr/parts/6hp
horsefly38425
got this one /need a little info model/vwb28906a/ser86x10117 it is real clean but someone tryed to remove l/u with a hammer A BIG HAMMER /it will not idle vary well at low rpm ck'd carb&fuel pump. flaps in f/p had been bent tryed to flat them back out it helped some /top air screw has little efect at all/bottom one works ok /which one would be idle/the one that goes in top has been cut off really don't know how much it may be the one causeing idle trouble anyone keep l/u parts/ck'd e bay no luck maybe i should clear up thats been cut is the insert that goes down not the adjust one on the side.which yrs/hp l/u will work if i find one :rolleyes:
alcan
Re: monkey wards yr/parts/6hp
Hi Horsefly<br />I have your motor listed as a 1967 model.tese motors were made by Chrysler and are the same as Chrysler badged motors. I realy can't make heads or tails of the rest of what your problems are. Grab a Chrysler manual and see if you can sort things out a bit.
