moomba movius 2000 need help with my propeller shaft
sebasendallas
i just broke my strut and i bent the prop shaft , any one now what are the sizes of my shaft to try to get one on line or any one know if i can repair it thanks
Don S
Re: moomba movius 2000 need help with my propeller shaft
Check with your local Moomba dealer to find what they installed in the boat. You could also check with your local prop repair shop. They normally so prop shaft, strut, and rudder repair.
sebasendallas
they said it cant be fixed do yo know if Four Blade Propeller 13x13 Pitch 1' Shaft with Right hand rotation fit in my boat ??
TyeeMan
Master Chief Petty Officer
Remove your damaged prop and prop shaft, bring that assembly to the dealer and ask for the exact replacement. Pretty simple way to make sure you get the right stuff. If at that time you want to upgrade to the 4 bladed prop they will be able to tell you right then and there if you can do it.
