Mooring cover to trailer
oldjeep
Thanks for all your responses!!
Oldjeep- the strap up front is a great idea, going to talk to my guy about adding one, without snaps it's tricky to get cover on.
Once you have your cover ratcheted down do you have a consistent tight fit around boat? My cover seems a bit loose on sides, bow and stern snug, although based on picture I posted I need too readjust ratchets before tightening, as you can see they are touching.
Thanks again
Yes, I get a tight fit everywhere - but this is a cover built for Malibu not aftermarket so I'd expect it to fit perfect. I'm curious how yours can be tight front and back but not on the sides unless the straps are not continuous from front to back, or if they are not under the rub rail all the way around.
The front strap is something I would have never thought of, even though I used to have a heck of a time with my old boat and getting the front to stay put while I was putting the cover on in the water.
I should say that while my cover is meant to have no trailer straps, yours might be meant to use them even though they seem to be built in a similar manner - I'd check with whoever made it.
