More hole shot, less top end......
chubcobear
I am running a 13.25X17 prop now. If I wand more hole torque and less top speed, which size prop should I use? 1987 Johnson 90hp, 16ft open bow, fibreglass hull. Thank you.
QC
Re: More hole shot, less top end......
You should post your wide open throttle RPM to start any prop change discussion. But the easy answer is to go down to a 15 inch pitch and try it . . .
Dhadley
Man, I would think that a 17 on a V4 on a 16' boat would be a rocket out of the hole.
chubcobear
It is. I am trying to understand the relationship between pitch and torque. It appears that when pitch goes down, torque goes up. BTW, top rpm is 5000 now m/l. I am very happy with my set up now. Trying to understand. Thanks to you all.
