- Joined
- Apr 17, 2002
- 71,417
Re: More HP
Hey Walt,.......... I Think you're Wrong on this point,.......<br />Matter of Fact,....... I Know you're wrong on this point.........<br />Vortec Heads will bolt onto Any of the SBCs,...Even the 400cid blocks(steam holes still need to be drilled)..... <br />The Difference is in the Intake Manifold,...Not the Head/Block area, or the Exhaust side.....<br /><br />The Only other point in your post that I'll take issue with is the quest for a 4 bolt Block,..........<br />SBCs have an Extremely Stout lower end,.... 4 bolt blocks Really Aren't Nessessary,... <br />Til you start Spinning in Excess of 6000rpms........<br />And, That's Not an Issue in a Marine Application........ <br />The Alphas start to Come Apart at anything over 5500rpms or so,.. Anyway.....<br /><br />Just How Many SBCs have you run across that Dumped the Crankshaft,.??...<br />Of them,.. How many were 2 bolt blocks, Vs. 4 bolt Blocks,.??....<br />And,.. How many were Blown because of torsional Flexing,.??.. Or more likely,.. Lack Of Oil,.??.....Or Excessive RPMs....<br /><br />Again,...... Not to start a Pi$$ing Match,......<br />Just to Clarify things.......<br /><br /><br />(Tony,.... Of Course I Don't Know for Sure,.. But I think he's talking about heads with Larger Valves,+ Big intake runners...Vortec heads Don't fall into this category..)Vortecs wont work on the older 4 bolt blocks,
