I have been reading on this topic for many hours now...and I guess I am just missing the basics at this point but I really want to give the "luber" method a try to free up my really stiff steering.
First I need to say I am a total newbie (in case you didn't see my name..lol) I don't even know what a tilt tube is yet...and yes I have tried to figure it out. Thought it was part of the steering but now I am seeing it as the bolt that the motor tilts on....sigh.
As for my steering...when I got the boat it had a home made deal in the back that held the steering cable in place.
I found this in under the splashwell (hoping that's the term...lol) and am pretty sure I need to use it instead if it fits.
But I cannot get the metal nut thing (it's an electrical outlet box connecter I believe) over the larger diameter tube.
Does this tube unscrew or come off somehow? Not sure how he (previous owner) got it on if not.
Once I figure all that out it's on to the luber...first I would like to know if my steering cable (ride guide rack and pinion) is a type that can be "lubed" or freed up? I know some don't like the idea of that but it's all I can do at this point.
If a luber setup will work for mine...how do you attach it?
I have seen several versions of the home made luber but still have not seen one attached so not sure how to do that.
My "thinking" is that I make the luber long enough to fit over the two tubes and it screws into the fitting that is pictured.
But if this is the case does the oil / lube cocktail just get pushed through this crimped end under the fitting?
Here is a photo with these questions in case I don't make sense..lol
I am hoping someone can help me out with these as I am eager to finally get this boat out for a test run....was going to do it with the bad steering but thought I may as well try this first. My steering is pretty darn hard and wouldn't seem like much fun for a day on a small lake.
