duckhunter55
Thread starter- Joined
- Oct 13, 2007
- 94
This is probably about the 6th problem i have had with this motor. After changing the lower unit with a completley different lower unit, I cant get the motor to pump water. As i have been told, i 1st, took lower unit apart, replaced impeller put back together. nothing. 2nd bought new t stat, still nothing. 3rd checked all lower unit passages and the rubber grommet on top of pump housing. still no water. 4th used an air compressor to blow up copper pipe and then down t stat. When i blow into the tstat i can only feel air coming from pee hole line. When i blow through pee hole i feel it out of tstat. But i cant feel any air from anywhere when i blow through the 2 exhaust holes on rear of leg. When i blow up copper pipe i can feel it at t stat and vice versa. And lastly if i pour water down tstat it only comes out of the little tiny, i guess, lower unit drain off holes. Run motor at river and in bucket but still cannot get any water out of pee hole or exhaust holes. Also the drive shaft has the little key for impeller. And lastly i was told about a rubber grommet where the top of copper pipe goes which can sometimes swell and resrict water flow? Sorry for long post
