colossus0706
Thread starter- Joined
- Jul 27, 2010
- 16
So the Smart Tabs are installed and all of our seats and seat backs have been completely re-double stitched so now we're ready to take the boat out again.
We've been out twice so we're still learning and I've got a few questions:
1. There are two drain plugs on the boat... I believe the metal plug is the bilge plug which is connected to the easy oil drain system. I believe the plastic plug is the transom drain plug. Please correct me if I am wrong. So far I've just been plugging and unplugging the black plastic drain plug. It seems like some water stays in the bottom of the transom... should I be unplugging both plugs every time?
2. When do I use the bilge? How do I use the bilge? So far the only switch I use on my Q4 dash is "Master Power" so I can turn the radio on. I assume I need to use the bilge if I get a bunch of water in the rear engine compartment but so far that has not happened.
