Texasmark
Thread starter- Joined
- Dec 20, 2005
- 15,055
Seems on these V6 Mercs, the water from the heads exits via the thermostats, once they open (120F); that is, the water that's not diverted to cool the exhaust manifold which is there always; has to be or you would burn it up.
So they have a 3/8" tubing arrangement that sums the output of these two stats and delivers it to the lower part of the power head head where it is dumped in to the exhaust horn(s) in the mid section to go out with the exhaust gasses.
Teed off this, at 90 degrees, is a 1/4" to 5/16" rubber tube that goes to the pee outlet mounted in theside of the cowling.
So if you have one of these critters and have been wondering about a couple of things, I may have some answers for you.
1. Pee does not (can't) exist till the stats open (120F). I really don't like this as if you have an impeller problem or clogged water passage to the head, you won't know it till the over temp horn sounds at 195F regardless of when the stats open.
My 90 hp is a later model 3 cyl, and the pee comes directly from the exhaust manifold jacket; water is there always if the engine is running; much better for checking the impeller, but does nothing to catch a stuck stat till the OT warning goes off......seems they can't win for loosing. :%
Back to the Pee outlet.
2. Since the tubing to the pee spiggot is much smaller than the tube from the stats, and since it's at right angles to the flow, and since there seems to be minimal restriction at the end of the stat discharge (for back pressure to assist the pee outlet), by definition you will have a weak pee stream......when you finally get it.
Just my observations.
Mark
Mark
