rrw
Thread starter- Joined
- Oct 9, 2011
- 104
Hi, more issues with my 1994 Johnson 9.9 electric start remote motor. I got it last fall, never hearing it run. This spring, I cleaned the carb, replaced the impeller, and started in the shop in a barrel, it ran beautiful. Then it sat a few weeks, on the water it ran like crap, I found it was only sparking on one cylinder, thanks to some of you guys for advice I replaced the power pack, it now runs a little better and fires on both plugs, but won't stay running for more then a few seconds below about 1800rpm, above that I can keep it going if I hit the primer solenoid once every 3-5 seconds. I took a spark plug and bent the finger out to about a 1/4" gap, with the motor running I checked both plug wires, they both throw a Orange looking spark, and the really weird thing is the motor runs better on either of the cylinders by itself then with both hooked up.
Things I've checked: pulled hose off carb, while cranking fuel pulses out heavy, took carb apart, everything seemed ok. Pulled fuel pump apart, looks good. Tried running on different tank.checked compression 105 psi, checked grounds on coil, cdi, battery etc.
Really stumped, keeping it running with primer would lead me to fuel delivery, but seems good.Orange spark at 1/4" gap probably isn't terrible. And why does it run better on 1 cylinder than 2??? Please help, its time to troll! Ryan
