More problems - Merc 400
lindy46
One problem after another working on this motor:(. I'm trying to pull the flywheel to replace the timing belt. I have a fairly expensive harmonic balance puller that came with a variety of hardened bolts. NONE of them will fit the threads on the flywheel. I tried numerous bolts I had in the shop hoping I would find a match so I could go purchase three hardened bolts to work on this flywheel. Did Mercury make a special bolt so no-one can work on this motor themselves? Frustrating.
Chinewalker
Re: More problems - Merc 400
They are 1/4-in. 28tpi bolts. Should be able to get a set of grade 8s at the local hardware store...
lindy46
Actually, 1/4" was too small and 3/8" was too big, so I took a chance and got some grade 8 5/16"x24 bolts, and they fit! Maybe tomorrow I'll tackle pulling that flywheel, once I rest up, meditate on the subject and ask for intervention from the Mercury Gods! I'm sure it won't be as easy as pulling a Johhnyrude flywheel - nothing has been easy on this motor. Anyone want to trade a nice 45hp Merc for a 40hp Johhnyrude?:rolleyes:
lindy46
WOW! Got the flywheel off with little problem and changed out the timing belt. All back together within an hour! Now it's on to the impeller, as soon as I find the dang spanner tool to remove the water pump cover. Been looking on Ebay for several months and no luck. Well, I've got lots of time before Spring arrives.
