dtwallace84
- Joined
- Jun 27, 2007
- 39
I have a 19' searay with 140 gm I/O and the wake is not very good. I new this when i purchased the boat, but is there any way to get more taller wake out of a boat like this?
agreed with the fat sacks. keep in mind tho when you add weight, your driving skills at low speeds deteriorate. Also keep in mind your weight capacity and the placement of the weight. I use 2 each 250 lbs upfront to push the bow down and a 600 in the locker. The fat sacks are the way to go since you can just dump them and turn your bilge on to conserve gas when you are not wakeboarding. I got mine from ebay flyhigh store 7 years ago along with the pump. the only prob I have had was just 3 weeks ago I lost one of the fill valve seals on the 600 lbs. but it was an easy fix.
