I just had my '95 3.0 rebuilt and install last week. I blew the coupler at the end of our week long vacation. Suspect alignment issue. I'm wondering if I have put the bolts/washers back on correctly? I looked at the bolt and used the different shades on the bolt to figure out what I thought was correct. However, since I have blown the coupler, I suspect maybe that was the issue.
This is how I have put the bolt assembly together starting from the top of the bolt and working down:
aluminum washer (about 1/2" thick)
aluminum flat washer (about 1/8" thick)
fiber washer
double coiled lock washer
Engine bell housing
Gimbal/Transom mount
aluminum nut
Is this correct or did I inadvertently miss-align my motor by assembling incorrectly (and blow my coupler)? (I didn't change the front mount at all, so I didn't think I needed to to realign anything).
Looking from the rear (without using an alignment tool) it looks like the rear of the engine should be up a bit (or the front dropped).
Here's a picture from the top:
If the above is not correct, how should it have been assembled? Using my "keen eye), I'm thinking the lock washer maybe should have been put between the transom mount and the motor bell housing?
Is there an assembly picture from a manual someone could copy perhaps? Or just listing the order is fine as well.
If there is something that goes between the transom mount and the motor bell housing, is there any hints on how to keep the part(s) there when installing the engine?
I am currently trying to make (or buy a alignment tool) as well to verify the alignment.
fiber washer
Engine bell housing
aluminum nut
