DayCruiser
Ensign
- Joined
- Sep 24, 2004
- 953
1990 Mercruiser I/O 130hp 4 cylinder<br />New Plugs and wires put in last year. New Battery this year. Charging instrument doesn't show a short. New choke put on Carburator before winterized--shop did work.<br />Riding along the boat will jolt you like it is going to cut off then instantly it will keep going like normal. It will sometimes go long periods of running without doing this before it becomes more frequent<br />I have emptied out the water seperator 5 times. I could not see water in the clear bottle I poured it into. Did see some black specs. But each time I emptied it the boat ran better than when I first started running it--except on the last outing where it stalled out under a bridge and then flooded. I had to put the throttle a little forward and keep on trying to start before it finally started after around 30 minutes. ON the way back home it cut out the worst.<br />Any ideas to what might be the problem?<br />When I got back home I bought a new seperator and then poured 16 oz of seafoam in gas tank and plan to test it out again today.<br />thanks in advance--good to see yall again this year!
