ledzeppelin135
Thread starter- Joined
- Jul 27, 2011
- 129
Hi, lately when I have been running my boat at wide open throttle it will get up on plane for a minute or two and then it will suddenly lose power and you have to decrease the throttle lever and run it at a little more than half throttle and if you attempt to speed it up, it will bog down and die. If you put it in neutral and rev the idle lever to full throttle it will get there and stay there but then putting it in gear will only allow it to go 1/4 throttle. After letting it sit for a random amount of time it will suddenly get back to normal for a few minutes at wot or for probably ten-15 minutes at 90% throttle. I decarbed the motor by putting seafoam in cylinders and spraying it in the carbs twice and that seemed to pick up the rpms with more weight in the boat but it also kept dying. I also replaced the plugs and it is still the same thing. I have not rebuilt the carbs as I dont have a repair manual but if you can walk me thru doing this or suggest anything else that may be causing this I would appreciate it. Thanks
